Re: '96 125 hp max rpm?
your 125 h.p has a rev- limiter. the rev- limiter is set at 5250 r.p.m s. this rev- limiter is used to prevent upper crank shaft failures. try to prop-out the motor at 5100+-100 rpm at w.o.t and trimerd out. you should try to run the motor "in the rev. limiter" (5250-rpm) as little as posible. good luck!
