96 Evinrude 50hp trying to disconnect VRO pump wont run pass mid speed
boobie
Re: 96 Evinrude 50hp trying to disconnect VRO pump wont run pass mid speed
Sounds like it's running on one cyl. Pull each spark plug wire one at a time and see if you have a dead cyl. If you have then check the compression and the spark.
cody8543
120psi on each cyl call boat shop they are saying there are five wire that I need to unhook because it thinks (motor) has no oil were are these wires an what do I need to do with them
Chris1956
Is that a carb motor or a FITCH? Carb motors do not have limp home mode. I do not think you can use premix on FITCH motors....Model number would be real helpful
tx1961whaler
No such thing as a 1996 50hp FICHT
cody8543
Im being told in getting an alarm of no oil so that is preventing more than 3000rpm this happen after disconnecting vor pump am mixing 50/1 in the tank
Chris1956
I do not believe that feature exists. Disconnect the wires that go to the OMS pump, to silence the alarm. Check for all spark plugs firing. Check for overheat, as this kills spark to part of the motor.
cody8543
It run fine on the hose rev up an down from idel to 6000rpm on the lever but on the lake in gear will only run 3000rpm
milliesdad
May I ask why you are wanting to disconnect a working VRO?
It is not a good idea to run an outboard past idle whithout it being under a load (either in a tank with a test wheel or on the water).
scumfrog44
ALSO - check the brand of plugs. Your motor is designed to run Champions.
Strange but true. Autolights, NGK, etc... will make your motor run different and
with that you will be chasing gremlins. Especially at Idle.
cody8543
Running champions an ur right on the difference between champions an ngk
cody8543
If its pumping water good shouldn't be over heating correct an
Chris1956
The telltale is just a sample of the water it is pumping. If you want to know if it is overheating, remove the cowling and put your hand on the cylinder head. If you can touch it for a few seconds, it is not overheating. If you see burned paint, it is overheating, so look before you touch..
cody8543
Left wife stranded on lake she threatened to sink it so its in the shop now they are thinking a plug carb or a power PAC brecking down
