96 gn tb 5 ign
jwkoehn
does a 96 tb 5 ign system have weights in the distributer ?
Don S
Re: 96 gn tb 5 ign
Nope, all electronic
jwkoehn
Re: 96 gn tb 5 ign
no spark advance 8 btdc @650 8-12 btdc @ 3500
Don S
Re: 96 gn tb 5 ign
Did you take it out of base timing mode?
Re: 96 gn tb 5 ign
Man,...... Loosen up those Fingers Dude,......
Trying to Dig Info out of you is Not why We're all Here,.....
Break Loose,+ Tell Us what the heck is going on,+ How you got there.......
With 1 word replys,.... All you're going to get around here is,......................Lonely...................:rolleyes:
Re: 96 gn tb 5 ign
Actually Bondo his breivity is refreshing.
Ayuh,......
Ya got Me Good with that 1,...... I had to look it Up.....
Btw,..... You spelled it wrong,........;)
brevity
Main Entry: brev?i?ty
Pronunciation: \ˈbre-və-tē\
Function: noun
Inflected Form(s): plural brev?i?ties
Etymology: Latin brevitas, from brevis
Date: 15th century
: shortness of duration; especially : shortness or conciseness of expression
:D
bomar76
Re: 96 gn tb 5 ign
At Least He Doesn't Capitalize Every Word.....
JustJason
Re: 96 gn tb 5 ign
like posts like this??~
PLz HEELP!! EYE gOt A 67 OR 76 MuRKeReRY, DUnO WIch.. wILL fIND OUt Too mORROW. bUUT IN meenTIME ANYONe HAVe ANY cLUES. MOtER Iz bROOKE.
TilliamWe
Banned
Re: 96 gn tb 5 ign
Spelling was never my strong suit Bondo-o. I am surprised I got that close!
jwkoehn
Re: 96 gn tb 5 ign
ok 96 gm tb5 ign system used mercruiser manual followed instructions to the letter to set timming . motor starts ok at 8 btc revs to 3500 w/ no problem watching the timming while running I am getting no more than 8-12 btc and the engine is dogging . If I manually advance the timming it runs great But I have starting problems It seems the only way I can get any advance is to do it manually while running Also I have an anti knock module on it .It has never knocked that I could hear I did replace the a/n sensor Is it possible the a/n module is preventing any advance ? I hope this is a little more thorough . It appears that nThis system is stuck in base Timming mode and is unable to return to normal operating mode.
John_S
Re: 96 gn tb 5 ign
What engine model do you have? I am guesing a 5.7LX or 350MAG or I could guess something else?
Do you know the timing module curve? it is usually on the ICM, such as V8-24S.
Was the knock sensor replaced for the same problem? or was it broken off or something else? Was the replacement the exact part number for your serial number engine?
Have you gone thru the knock module diagnostic tests in the service manual?
Is your battery fully charged and outputting the correct voltage? The ICM will behave flaky at lower voltages.
What voltage do you read at the purple/white wire when not in base timing?
jwkoehn
Re: 96 gn tb 5 ign
engine model is the 350 lx boat is still in storage so I can"t check anything else on your list I will follow up later Thanx Jim
newport dave
Re: 96 gn tb 5 ign
You may have a problem in the knock control system. Some info for you;
knockmod
Re: 96 gn tb 5 ign
Ayuh,........
Now We're Diagnosin',.........:)
