Chuck4741444
- Joined
- Jun 6, 2020
- 122
I purched a old lower unit. Removed all parts cleaned and reassemble per manual. While test running is on a hose. After 30 minutes or so, water slowed down and motor was getting hot.
Removed it this evening, the water pump housing had a gummy sticky stuff blocking the passages the impeller was sticky.
The only thing on the lower unit that I can find wrong is the is slack from the to and lower shaft. I believe the shaft was moving up and down causing the impeller to rub top and bottom of the housing.
I removed the roll pin and there is a metal adapter the roll pins go through that appears to be worn out. Is the 2 part drive shaft connect tight so the top shaft hold in place?
