98 115 Johnson been sitting 9 months
GatorMike
Ensign
Re: 98 115 Johnson been sitting 9 months
Agree.
I would not be surprised if you find rust.
Yeah I am sort of expecting the lower left cylendar to be rusty. When I pulled the spark plugs that one had rust on it and the others were pretty clean. If I get an hour free this afternoon I will probably go ahead and pull the heads. Will let you know what I find.
GatorMike
Ensign
Ok I pulled the head off the left side since that is the side where I found rust on the spark plug. The lower piston was extended all the way out. There was some rust and crud on the top of the lower piston and a little rust around the cylendar. Most of it wiped right off with an oily rag. Since the piston is all the way out there is only about 1/4 inch of cylendar wall exposed so it is kind of hard to tell.
The top cylendar was back part way through the exhaust ports. It was fairly clean except for a pile of loose crud around the lower exhaust port. Probably just crud washed out of the exhaust by the PB Blaster and Mystery oil I had poured in it.
I tapped the lower piston a couple of times with a hammer and block of wood but it didn't move. I'm still not ready to give up on this thing yet. Unless the inner part of the motor is rusted nothing I have seen so far looks too bad. It all apears to be surface rust, nothing pitted that I can see. I think I will blow it out real good with my air compresser and then keep spraying it down with oil for a couple of days. I read a couple of threads about a 50/50 mixture of ATF & Acetone, anybody know about that? Is this concauction any better or worse than PB Blaster or Marvel Mystery oil?
bob johnson
squirt some PB baster in the port you can see in the cylinder and blow in there with the air hose, hopefull you will coat some of the crank...
good luck
bob
