98 7.4L MPI manifold torque sequence
Shaun78
What is the special order to torque the nuts that hold the exhaust manifold to the head?
I actually had to use a dremel to grind & sand the crud attached to the head in order to get a smooth surface again. Yes I was careful not to remove much material, just the crap that needed to go.
Don S
Re: 98 7.4L MPI manifold torque sequence
Are you talking intake or exhaust manifolds?
Shaun78
sorry, exhaust manifolds
Don S
Start in the center and work your way out to the ends.
Coors
and use a straight edge.
HT32BSX115
Am I losing it? I could have sworn he said INTAKE manifold...
Don S
No, he didn't say intake or exhaust originally, he did go back and edit the post to say exhaust.
Shaun78
Thanks. Don have you or anyone ever had to grind the crud off the head to make a smooth surface again? (exhaust manifold) It was more than just the old gasket, there was cast almost welded itself to the head, maybe part of a corroded manifold?
