Hello everyone,<br />I really need some help with this one cause its killing me...<br />Like the title says, 98 Evin. 115spl is having intermittent problems reaching WOT and has power loss of about 1000 - 1500 RPM in the 2500 - 5300 rpm range. Below that it is ok. <br />What I've already tried-<br />Replaced plugs<br />Replaced fuel water separator<br />Run B-12 fuel treatment (new fuel anyways)<br />Tried pumping primer ball during problem- no change<br />Tried pushing in key- no change, just stalled after a bit<br /><br />I've searched the archives and found many, many similar posts but none with a real resolution. Here is some more background on the problem. By the way, compression is fine.<br /><br />Engine will usually (not always) run like a champ when cold for the first 15 - 20 minutes, then the problem shows itself.<br />The problem is often related to the plane angle of the boat- once it reaches plane, power comes back SOMETIMES.<br />Power sometimes comes back after hitting a big wave and shaking the boat up a bit.<br />On some occasions, it will be running fine all day, then I shut it down for 5 minutes, start back up and the problem is there again.<br />Sometimes after running at full throttle (with power loss) the power will just suddenly comeback and the boat takes off!<br /><br />When the problem is happening, the engine has a bit of a lower tone. I've ruled out fuel starvation by pumping the bulb but pushing the key in didn’t do much for me. The engine lurched for a split second before stalling and being flooded, but it was not an instant pick up by any means. I've thought maybe it could be a problem with a cylinder not firing, but it seems that it would run much rougher. The tone is lower, but it is not running rough when this happens. <br /><br />Sorry for the long post but I want to put EVERYTHING in here that is happening to give the clearest most accurate picture. Thanks so much for any help.<br /><br />-Chad
