- Joined
- Jul 23, 2011
- 53,259
Moat salt water boats with low hours and rebuilt motors are marina dock queens and the exhaust rotted out requiring a rebuild
The nice thing about my boat is that it has been used pretty consistently throughout its life. About 40 hours per year. I am the 4th owner, having owned the boat for 6 years now. The PO, 3rd owner, only had the boat for a couple of years. So, the first 2 owners split the first 14 years (+/-). All 3 of those owners were Lake Winnepesaukee, NH.
The boat did not see salt water until I bought it. The engines have never seen salt water, because of the closed cooling that I added.
Wow,..... Hard to believe it was that long ago, you were up here lookin' at Chris' boat, 'n stopped by,.....![]()
if it was my boat, I would do nothing more than pulling the heads, inspecting the bores (above the pistons with a bore gauge for diameter and run-out)
then I would do some mild porting and bowl blending to remove casting flash, port match the exhaust, get a valve job and bolt the heads back on and go boating.
(and yes, the evil little guy on my shoulder is saying "build a pair of 540's however the realist in me is saying cant do anything until you pull the top end and look)
I've enjoyed this thread enormously. I never really thought about the unique, and potentially expensive pitfalls, of maintenance on 1000 hour motors that might be sold. Great input from some knowledgable folks. Made me sit and think about things. Learned a few things, I might add. Thanks!
Rick
Seems to me, that if you want high performance, swap to a V8. The cost to add performance stuff to a V6 quickly exceeds its value in a boat. Jumping to a 5.7 or 6.2 would surely be a more cost effective way to jump the shark.
Yes and no. The 'price' of the V8 over the V6 is about 100kg. In a small boat, that can be significant... Particularly in a stern drive configuration, with all the engine weight at the back.
Chris......
There was another guy that Tail Gunner helped with a 4.3 rebuild, after he had finished his own. The guy didn’t stick around though.
Found itMember’s name RSBJ Rebuilt his 4.3 into a high performance version.
https://forums.iboats.com/forum/eng...ing-a-1998-mercruiser-4-3l-need-advice-please
