I left the marina and went about 500 yards and it felt like the throttle was pulled back part way. I was still on plane but felt like about 30% of the power just slowly backed off. Gave it little more but it still felt like something was missing. I put it in idle and even turned it off. It started again just fine but took forever it get back on plane. Checked the carbs today and they all opened fine. Shift cable ok to. I will check the fuel filter tomarrow. The only other thing I can think of is I did use some older oil that I had from my other boat. It was in its original container and I had only used part of it.. Does oil go bad? Where should I start looking? I'm open to suggestions. <br /><br />130 Johnson 1999<br /> Thanks James
