99 Monterey 276 Transom Replacement
Lou C
First decide if you’re goin go to keep this boat a long time or not. Then evaluate rhe condition of the rest of the boat & the running gear before going forward with a project like that.
  • Like
Reactions: KJM
Monterey276
good luck, I would personally fix the transom this winter
I seriously considered it but I had a lengthy conversation with the guy in my area who specializes in restoration jobs. He said it’s actually a much easier job the further along the rot is. It’s much easier to do the demo work. Made sense to me anyway
Monterey276
I didn’t have plans to sell until this came up. I initially thought it was a death sentence. It’s a great looking boat IMO. Everything works perfectly.
KJM
Thanks for the advice everyone. Just wanted to share the rest of this story. After drilling a couple holes I’ve found that it is definitely wet and at the beginning stages of rot but it’s actually not terribly bad yet. I don’t have any stress cracks or the interior glass beginning to delaminate. I had a mechanic pull the engine and crank down the bolts but that only slowed the leak down temporarily. (Another indicator of it getting squishy in there). He says that there are spots he could see the plywood core between the inner and outer transom assembly and it didn’t look bad at all. My plan for the fall is to wire and plumb in a backup bilge pump totally independent from the primary pump. I’m going to pull the drive off and look for any spots water may be seeping through and put some 5200 around the outside transom assembly. It obviously is going to have to be fixed correctly within the next few seasons but I don’t think it’s as bad as I was initially told. I’ve watched a lot of YouTube videos recently about rotten transoms and mine isn’t even close to that. Also, it doesn’t look like too bad of a job, I’ll do some research and be ready to tackle it myself a few seasons from now.
Don't mean to be a downer, but you are putting off the inevitable. A wet transom in places means a rotten transom in places. If you have the engines pulled(?) why not just bite the bullet and dig in? It ain't fun but it is doable. I would be ready to face rotten stringers as well, at least where they meet the transom. I would also suggest using a composite material for the core of your rebuild, you don't want to do this twice!
KJM
I would like to know what he said! Maybe I'm wrong but ripping apart an entire boat instead of the back end of a boat don't seem easier to me. Could it be he's just looking for a bigger job down the road?
tpenfield
Once wet, rot tends to go exponential and can go quicker than you think.
Monterey276
Nah, I didn’t get that vibe from him at all. He said if I wanted to have him do it, it wouldn’t be until end of next season anyway. He has that many jobs in front of mine. Again, it needs to be addressed but has probably been leaking/rotting for years. I’ve only discovered it this season. One more years not going to hurt IMO. It still floats … mostly
drewm3i
My advice: take the TPenfield approach over winter.
Pull the engine and transom assembly. Cut the inner skin off the transom where it's wet.
Once removed, inspect the wet wood. Depending on severity, dig out what's rotted and repair with either new core or epoxy mixed with milled glass fibers.
Drill a bunch of holes in the existing wood and inject ethylene glycol a few times into the holes. Keep a heater in the bilge to dry out the wet wood. Once dry, fill all of the holes with epoxy. Then glue the skin back in place with epoxy and clamps. After that, tab over all of the joints and paint the bilge.
This will be a lot easier now rather than later
tpenfield
Having been there and done that. . . Nip it in the bud stages. It is not all about the transom, and a delay may enlarge the scope .
tpenfield
Keep in mind that all of the wood ‘bones’ of the structure are connected and moisture travels quickly among the component.
drewm3i
Share the link of your 330 SS project. I think it fits the bill here.
drewm3i
Monterey276
Hey all, wanted to send an update on my leaky transom assembly/rotten transom situation. I drilled quite a few more holes in various places along the stringers and motor mounts and seeing mostly brown/black wood shavings that come out. I made a decision that y’all are right and it shouldn’t wait any longer so I guess I’ll be attempting a boat restoration project. Last Wednesday I disconnected everything on both engines, and with the help of the marina, pulled them both out. They are now sitting in my garage until I get this resolved. Over the weekend I began removing hardware, electrical, plumbing etc. I have so many questions I don’t even know where to begin. I’ll post some photos soon along with the beginning idea stages of my plan for review. Hopefully a few of you more experienced members won’t mind lending me advice on the subject.
JASinIL2006
Sorry you found rot, but good on you for taking care of it properly!
You are in the right place for help.
tpenfield
We are going to need lots of pictures as you go, as it will help with responses.
KJM
Take lots of pictures for your own use as well as you take everything apart, esp. wiring, so you will know how it all goes back together down the road.
Monterey276
Here’s a few from right after I finished up removing the engines. We pulled these while it was still in the water so I could see where the leak was coming from. I have a video of that if I can upload videos here but it was sort of inconclusive anyway. It seems to be trickling down the back side of the Y-pipe somehow but I couldn’t see how without removing more stuff. Next step is to remove the drives. So here’s question number 1, how do I know for sure the drive is in forward gear for removal if the linkage is disconnected?? I can see the shift lever moving the drive cable (I left the linkage all connected, just removed the bracket from the manifold studs). I wanted confirm with someone first on this cause I didn’t want to try and remove and potentially damage something if it’s not actually in forward position. I have already disconnected speedometer tube.
usually the easiest way is to remove the drive before removing the motor.
