veritas honus
Thread starter- Joined
- Jun 13, 2010
- 1,876
I've been thinking about this for a while now... What are your thoughts on leaving the boat in the water with the muffs on. A large debris handling submersible pump flowing 600 gallons per hour through the muffs. The pump would be surrounded by a crab trap to keep large leaves and hydrilla from occluding the intake. The engine would have water flowing through it 24/7 throughout the cold months. Flowing water takes much colder temperatures to freeze than Lake Seminole has ever dished out. The engine can be started as frequently as desired. If the Army Corp of Engineers decides to drop the water level enough to ground the boat, I can run enough hose to keep the pump submerged. Will the water flow throughout the entire engine when not running? Am I out of my mind, or does this actually sound reasonable?
