Gromulin
Thread starter- Joined
- Jul 5, 2010
- 230
I'm new to "new" VP and Merc I/O's...my last boat was a 85 Glastron with 3.8 GM power and an OMC outdrive. The kind that jacked up the entire motor to set the trim. Lots of lovely things would happen if you hit the tilt button with the motor running, or if you tilted it up with the trim set too high...but I digress...
Heres the question, dumb:
The impeller - on a VP it's easily accessed and looks like it would take 15 mins to change from INSIDE the boat. Mercruisers are inside the lower unit, and require much more work, and disassembly to get to.
Did I get this right, or is the "impeller" (that's located roughly where a water-pump would be on an Automotive engine) on the VP not the same thing as the impeller on a merc?
Thanks in advance...
