matthewp
- Joined
- Jul 14, 2008
- 173
Hey everyone,
I joined last year, talking about my '85 Starcraft 21' center console and the rebuild that it needs. I fished it last year with few changes - waiting until this spring for a total rebuild. The weather has been warm enough the last few days to get to work. So far, I've removed the bench, console, wiring, and most of the floor) Still have the piece under the splashwell to get to. I plan to follow all of the steps so well-documented here in these pages by other starcraft owners (thanks for the info and inspiration) - clean the hull, gluvit, template the new floor from the old - epoxy, mat, etc....
One question I have is this: if I rivet the floor down and cover it with epoxy, mat, and whatever final finish I chose, the floor cannot be removed in the future without major surgery because all of the rivets will be hidden under the epoxy. Does this method concern anyone else for this reason? I know the first floor lasted 24 years - and the new one will be better than the factory floor when it was new. Still... makes me a little nervous.
Second question: From what I've seen here, the old foam is always removed - just as a matter of course. How can I tell if mine needs to be taken out?
Third question - when I was pulling up the floor, there were some aluminum pieces between the floor and foam. You can see the outlines in the photo looking toward the back after some flooring came out. What are these?
Here are some pictures before taking the floor up:
looking toward the transom:
http://picasaweb.google.com/lh/photo/ouh0Hmuhon9Gv7BJMy8j0w?feat=directlink
toward the bow:
http://picasaweb.google.com/lh/photo/OhKVdu7e5Rp_HADo0KsV3A?feat=directlink
bow flooring removed:
http://picasaweb.google.com/lh/photo/J68xZeEgd1juq00CJ9V1eA?feat=directlink
the foam (and outlines of those aluminum pieces near the splashwell
http://picasaweb.google.com/lh/photo/M19xF29ttylulorNXTre1Q?feat=directlink
How much Gluvit should I get? From what I've read, a gallon may be too much? I'll have many many more updates and questions. Within the next few days I hope to get the boat completely cleaned out and the hull cleaned and ready for Gluvit.
Thanks for looking!
toward the bow:
Thanks for looking!
