apw30534
Thread starter- Joined
- Jan 14, 2022
- 87
1997 Chaparral 2330 with a 250hp 5.7 Mercruiser and Bravo 3 with 3x3 26 pitch props. Boat is 3850lbs dry, hull is rated for 415hp.
Current top speed on the boat is 48mph with 2 people + gear.
I'm building a spare (355) engine that should be approx 365-375hp.
Engine details:
+.030" chevy 4 bolt block
Forged flat top pistons @ 9.6:1
Vortec heads with Manley race-flow stainless valves/beehive springs
Comp Cams XM270HR cam
Chevy dual plane intake + Holley 650 carb.
I'm interested in the best speed possible with the new engine + old drivetrain.. but will change props if needed. I know a Bravo 1 will go faster but I like the dual prop bite at lower speeds.
The current engine has no trouble digging out of the hole and getting to 4800-5000rpm with the current 26 twist props.
My concern is that this new engine will need a taller prop like the factory 454 boats used.
Should I be looking at 28's awhile ? or run it first and see how it performs with the existing props ?
I'm also concerned that the new engine will hit the Mercruiser rev limiter before running out of steam. It should make good power to 5500rpm. Maybe run an MSD distributor and CD ignition ?
Engine details:
