Re: Adding a second battery - what's on each battery
Sure there's an advantage and an easy way to do it. The advantage is, if I run accessories off one battery and starter off another battery, chances are I'll always have starting power. The way to do it is use the dual battery switch or Automatice Charging relay to keep the batteries charged. But, for the accessories, directly connect a wire from the positive terminal of your "accessories" battery to a buss bar for the accessories and a wire from your common ground terminal (this would be a large stud terminal that you SHOULD have both battery grounds and the engine ground ganged at) to another buss bar. Now, you've got a positive and negative buss bar for all your accessories, that will only pull from your accessories battery. Even if you run that one dead, you'll still have a full starting battery. The dual battery switch will still charge #1, #2 or Both, whichever you select. It will NOT turn off your accessories curcuit. You can install an "Accessories Master" switch, if you desire or an indicator light that glows when the Accessories curcuit has a draw if you're afraid of having stuff left on or parasitic draw from components with memory curcuits.
