Re: Adding an extra battery?
An ACR is a Combiner. Simple difference in terms is all.
The system above works without switching the batteries at all. Thats why it is designed the way it is. In normal operation both the house and start switches stay in the on position all the time. The parallel, or manual combine, switch stays off. Under normal conditions the switches would stay in where they are and the ACR, or combiner, does all the charging work. The reason for the three battery switches is to provide a way to turn off each battery individually. For instance, if you have a start battery that has a bad cell and will not stay charged you would turn off its switch and turn on the combine switch. This would allow the house battery to power the whole boat. Another example would be if for some reason your start battery goes dead, you would simply turn the parallel (manual combine) switch on. This will allow the good battery to boost the bad one and start the boat. The system simplifies things over a 1-2-both switch in my opinion. A 1-2-both switch works well if you are powering one system with two batteries. You simply select which battery you want to power the whole system. This system is set up to isolate two completely different systems each with its own battery.
The "start" battery system would only power the starter, the ignition and any gauges you may have. The "house" system would only power accessories, nav/anchor lights, radio and any other thing not related to starting or powering the engine.
You would have an automatic combiner to provide for charging the batteries while the engine is running. And a manual combine switch in case the combiner fails or you get a dead battery.
Like I wrote before, it seems complicated at first but once you set it up you can forget about it. And when something goes wrong you know you have it covered. I have been out there trying to fiddle with cables and monkey with batteries before and its no fun. This system in my opinion provides for nearly every eventuality.
See Link
http://www.iboats.com/Mini_Selector....216621--list_time.1174607647--view_id.342283
