Re: Adjusting hieght of outboard?? How do I know
That motor needs to be dropped your cavitation plate need to level or just under the lowest part of the stern.
Ventilation
Ventilation is a phenomenon that occurs when surface air or exhaust gas (in the case of motors equipped with through-hub exhaust) is drawn into the spinning propeller blades. With the propeller pushing mostly air instead of water, the load on the engine is greatly reduced, causing the engine to race and the prop to spin fast enough to result in cavitation, at which point no thrust is generated at all. The condition continues until the prop slows enough for the air bubbles to rise to the surface.[4] The primary causes of ventilation are: motor mounted too high, motor trimmed out excessively, damage to the antiventilation plate, damage to propeller, foreign object lodged in the diffuser ring.
[edit] Cavitation
Cavitation as it relates to outboard motors is often the result of a foreign object such as marine vegetation caught on the lower unit interrupting the flow of water into the propeller blades.
