The motor got quite lively,compression on two cylinders was 10 but in one 8.5 atmospheres and there was a gap in the piston,during the analysis it was found that went out the rod bearings and needle bearing piston pin.Please excuse the mess on the table photo was doing at the time of the parsing engine and medical purity there is no need,if not lost interest in the show then what happened after my work.Also,if something in my words is not clear,it is ignorance of the language,translate online translator.I don't know whether it was appropriate that I intruded on Your forum,if something is against your principles,then tell me,I will not interfere,it is simply interesting to communicate with colleagues on the hobby in other countries.By the way broken bolts can be etched by chemical solutions,are very well etched oxide of alkali used santehniki to clean the radiator(I don't know you use it or not) it is also convenient to drill drills reverse rotation,in most cases, the room just gets out and not have to cut the thread.Here is the thread we have the same problem,You have an inch and we have a metric,so we have to try not to break))) Can't insert a photo.What size and extension, you can load the files?
