IanFS
Thread starter- Joined
- Apr 21, 2009
- 188
Hi guys, can you help?
Alpha 1 Gen 1 Sterndrive
Is this normal?
It's the first time I've replaced a Gimbal Bearing. It installed very easily, too easy, I just tapped the installation tool with a club hammer and it slid in easily. I took great trouble to make sure the grease holes aligned.
However, when greasing the bearing via the grease zirk, grease oozed out between the gimbal housing and the gimbal bearing outer ring, not a lot but every time I pumped the gun, more came out. I know some of you guys would have changed a Gimbal Bearing a thousand times so......
Is this normal or is there a problem?
Is this normal?
