Aftermarket Ignition Parts - Which Brand?
phipps
I realize this will probably open a can of worms......
It looks like I need to replace a cracked coil on my 83 Evinrude 50. iboats has CDI, Sierra and Mallory. Of course there is always OEM.
Is one brand recommended over the others?
Daviet
Re: Aftermarket Ignition Parts - Which Brand?
I have had success with all the brands you list, sometimes the OEM part is not available to me when I need it and have to use the aftermarket.
boobie
JMHO but I'd go with the CDI.
rookie456
cdi looks to me like a better built coil, but if you switch one coil to cdi, you have to switch all of them. At least that is what the website I was gonna order from said for my engine.
Faztbullet
I use Sierra due to the warranty..... When you reassemble it make sure you assemble bolts and washers properly and do not overtighten as it will break the powdered core.....
rookie456
Why?????????
I dont understand why you would need to replace all of the coils either. I would think each coil would work independently, but this is the note I get when ordering a cdi coil for my engine.
Note: This style coil must be used together with similar style coils. They can replace the old style coils, but all the coils on the motor must be replaced.
Bob_VT
Well you have 2 cylinders and you do understand "advertising" don't-cha ;) companies always want to sell more! the choice is your's.
