alanfox55
- Joined
- Nov 17, 2011
- 476
How is air temp and changing air pressure in a high quality PCV boat dealt with? I can understand having to adjust to great changes in air temp but let's say 20 degrees. Say you inflate to full pressure at 80 degrees in the shade then you put in at a lake where the water is relatively warm and the day ends up being 100 degrees and sunny. Is the increase in pressure engineered into the construction of the boat so you don't have to worry about it? Do you carry a pressure gauge and air pump so you can constantly adjust to changing temp? I doubt if it's the latter but I don't know. So how is changing air pressure in a PCV boat dealt with. Thanks.
