bspeth
- Joined
- Aug 30, 2013
- 758
Re: Alignment bar does not go into engine splines
Got the tool to go in just like Frisco. However when I turn the engine over 90 deg. the tool does not go in easy.Is it necessary to pivot the bearing each and every time you check or only at the start.Here is how it sits: start-just like frisco,turn 90-hard to push in but it does bottom,turn 90-hard to push in but it does bottom,turn 90- goes in all the way with just a little drag.I have raised the engine 10 nut flats at this point which kinda makes sense that the mounts would have squished over the years,but not why the drive came off easy.Has anybody else had to make such drastic adjustments as well? Done for the day,gotta make dinner and have a beer.Will pick up with any suggestions tomorrow.Man I would love to get this off my plate!Thanks again-Blair
