Alignment tool won't fit into coupler grease extension
luskateer
boat is a 92 regal
motor is 4.3
outdrive is SE116
My mercruiser alignment tool is not going into the coupler properlyl The step is tooo large to get into the grease coupler snout.......does this take a special tool.
thanks
Don S
Re: Alignment tool won't fit into coupler grease extension
Well, no one here knows what "Your" alignment tool looks like, if you have an old Mercruiser bar, it probably needs upgraded to the (Now old) service bulletin.
here is a drawing that shows the newest updates.
attachment.php
Here is the 92 bulletin.
luskateer
you hit the nail on the head. Borrowed this tool from a deceased mechanics box. After wire wheeling away the rust its still too big. Will modify the ole tool and buy some ky jelly.
regards.
ziggy
imho, use some mercruiser spline grease instead. that's what you'll wanna lub the coupler with anyways.;)
Don S
Rust expands the metal. I would bet if he measures it with some micrometers, even with the rust off, it's likely to still be too big.
luskateer
good point about the rust.
was able to rent an alignment tool and set it right today.
thanks for the help
rich
