mesajeeper
Thread starter- Joined
- Jul 7, 2010
- 66
I am not getting power from the drive shaft to the prop.
Cruising at 3800 rpm when it felt like the outdrive shifted into neutral and the engine reved. I initially thought it was a linkage issue as I replaced the lower shift cable just a few weeks ago. Nope. Looked under the outdrive and confirmed the lever was pointing exactly straight (sould be in forward gear) but no power to the prop. Niether forward or reverse work. I suspected maybe the u-joints busted but they are fine. The issue is somewere between the drive shaft and the prop. I didnt hear anything when this happened. No snap, crackle or pop. Any idea what this could be? What would be the next step to diagnose? I am hoping I dont need a new outdrive but I fear the worst.
Thanks for the help.
