Alpha 1 Gen II question
sjm32157
What is the small hole (1/8 - 3/16" dia) for on the leading edge of the outdrive about 6" above the prop shaft housing just below the cav plate.
Just curious.
pinecrestwoods
Re: Alpha 1 Gen II question
If I'm picturing what you are saying correctly, that should be the pickup for your speedometer. They get clogged easily, so if your speedo isn't working, that's a great place to start. I first thought mine was just a nick, but a little exploration showed me that mine was plugged with wood or something. I was able to clean mine out by working a small diameter drill bit with my fingers.
cpubud
yes it is the speedo pick up
sjm32157
Thanks for the info guys. I also have the 4.3 LX in a 20 foot cuddy. The power is great and reasonably easy on gas.
pinecrestwoods
I've been happy with the 4.3lx, also. I actually didn't know exactly what I was getting when I bought it..... I just test drove it and thought, "That'll do." My boat is pretty light, and it makes me grin each time I stand on the throttle. I know there is more power out there, but my little 4.3 does just fine (and it does it quietly). My only concern is if/when we move to a larger boat- I guess I'll have to go up in engine, or it will be tough to accept a performance loss.
