Alpha 1 no trim up
LVANGEE
Lower unit trim works going down only . It is completely dead in the up position . Dead from both the shifter and the trailer swith . It does work when you jump the solenoid .
Outdrive is alpha one 1982
engine 350 260 horse
any help is greatly appreciated .
LVANGEE
Re: Alpha 1 no trim up
I jumped the big lugs .... sorry wasnt very specific . Are those solenoids both the same on that pump unit ??
Bt Doctur
Both the same. Might want to check for corrosion where the buss bar connects across both solenoids. If there clean, the replace the solenoid.
LVANGEE
I checked the bus bar etc. I have no signal coming from the switch down to the solenoid . I will have to find wiring schematic and trace it out ... thanks for the help .
achris
More fish than mountain goat
Or download the genuine service manuals for your engine and drive in the Adults Only section of the forum...
