Hi all!
I have a shift problem with my 5.0 Mercruiser / Alhpa1
I have been reading and reading. My lower shift cable went Kaput... I replaced the cable. Shifting fine now. However, the PO fixed the "symptom" and not the cure by clipping the Shift Interrupt to Coil wire. I have read the posts on the Shift Interrupt switch and understand how it works and the like.
After replacing the lower shift cable, I made the adjustment of travel to 6 inches as required. Shifts just fine. She drops into F and R with ease... Just in F to Neutral is the problem. I have to shut down the engine to get out of F. Makes for an interesting time getting docked
I spliced in new wire to the clipped wire. In the driveway on muffs, it iwll not start in gear as designed. However when I splashed her late yesterday, it stalled when I put it in F.
I clilpped the wire again and it started and motored in F / R just fine.
Bad upper cable? I had the Mrs. move the throttle and it doesn't bind.
Any and all help is much appreciated!!
Thanks!!
Jeff
Nuboat2me
Thanks!!
Jeff
Nuboat2me
