Alpha I Generation Compatability
Barneyfife
Re: Alpha I Generation Compatability
MY bad. Didn't realize the engines needed to come out to do so. Oh well, good excuse to get an overheard hoist setup!
chiefalen
If you got a garage with a tall enough ceiling maybe.
But a good tree with a real strong branch and a 3/4 ton comealong will do.
You need a least 8- 10 feet above the engine bay to clear the transom.
Closer to 10 feet. And the drive got to come off first.
Barneyfife
Thanks for the info. Am a pretty good mechanic just never messed with sterndrives before except for maintenance. Time to get a manual!
captmello
Like this chief?
I call this photo "Summer Fun"
sorry no help, Just practicing the with photo bucket.:)
Ayuh,... Great way to bump up the Post Count,...:D
Is that at 320,..??
I use either 480 or 640 or something like that...
It uses about 3/4 of the width of the pages here at iboats...
I just Hate it when ya gotta side-scroll to read the threads,....
I usually just totally Ignore the thread at that point...:rolleyes:
Probably the only things Worse are typing withnospacingpunctuationorsentencestructure:(
Or,...
THE FAMOUS CAP-LOCKS....:mad:
captmello
Is that at 320,..??
Yea, photo bucket wouldn't go higher for that photo, maybe 'cause its a cellphone shot.
Still trying to figure it out.;)
chiefalen
Yea like that.
Just happened i used a 2 bye 12 lashed between 2 trees and i pulled the boat in between the trees under the Beam. It's still there, i didn't want to damage the trees, with nails.
Been a few motors dangling off that beam. And maybe a deer this year.
That way if i was off a little i moved the comealong over ether way.
I had to pull out from under the motor about 8 times.
Cause i pulled the motor. Pull out the boat from under the motor. And lower it to the pallet on the ground.
Just knew it would be easier.
captmello
chief, didn't look anything like this, did it?
This one sat for a week under plastic before being called back to duty.:D
chiefalen
I knew i should have takin pics. But didn't want to get my wifes camera all greasy.
Yea just like that.
Had 2 motors side bye side, transfer the oil pan, oil pump, You know the drill.
Barneyfife
Thanks for all the replies and help. I plan to study the manuals, acquire some Gen II sterndrives and transom assemblies, then pull the engines. Will be a good time to put some new gaskets on the engines to seal up a few minor leaks, paint 'em, and give the engone compartment a good cleaning and painting.
Guess I'll be welding up a place to put the hoist...the gunnels sit over 6 feet high as she sits on the trailer.
Rod
