Alpha one Gen 1 U joint removal
Dubed
Are ya feeling lucky? With the corrosion on the other bearings. I don't know much but I would break it down just to see..if it looks good then put it back in
Good point
Dubed
Ok, time to press the bearings on and set the rolling torque.
What is the correct method for pressing the bearings on? One at a time or as a pack?
I assume one at a time, first one till almost in contact then the large spacer, then the last bearing till its just touching the spacer, then set the preload....
Or am I wrong?
Thanks
Dubed
After examining everything, my new thought process is;
Press on 1st bearing till it bottoms out on gear, with large spacer and races installed press 2nd gear on till it almost touches spacer (spacer should rotate freely) then set the rolling torque onto the new yoke with new nut and washer... as per Chris's video
Correct?
achris
More fish than mountain goat
Correct?
Bang on.
