Hello again all, as per my luck port finally is running right. Thanks to all for the help. Now, first trip out the starboard is heating up lol. Issue was in the impeller, so I decided this time around to change the impeller housing along with the impeller. The lower housing was stuck pretty bad and ended up destroying it while removing it. At the time I figured it did not matter, I have a new one... Well turns out that none of the Alpha one gen one, pre alpha or MR seam to be the same. Here is a picture of the new one that does not fit. Unfortunately I dont have a picture of the old one, one of the cleaning people at the yard thought it was garbage because I left it on the ground. But here is the difference. It looks exactly the same on the top side. But on the bottom side where it seats on the lower drive. The circle with the rubber gromit around it is completely different. The old one does not have a rubber seal and It is only about 1/8 of an inch tall, and it is just a circle 1/8 of an inch wide and hollow in the center. All the ones I have found online are either too tall by almost double or are solid through the center. I made a terrible diagram to try and show the difference.
