alpha one on merc 120 wiring questions
skinny1965
Ok so after a big job of replacing the wood transom I'm putting it all back together. well I need help with the locations of the 4 wires from the gimbal housing two have bullet ends and I think I have seen diagrams with those but the other two have eyes on them and I cant remember where they go. I took pictures when I took it apart but had computer crash and lost them
also the wire from the distributor goes to the - side of coil correct
pretty sure I have the rest covered
any help is great
duped
Yes, dist to negative on coil. Sounds like your other wires are for the trim switches. Couldn't tell you exactly where they go on the 120 but I'm sure someone else will chime in.
Bt Doctur
the bullet ends go to the trim pump wiring, the eyes go to the plastic block on the front? of the engine.
skinny1965
thanks a tongot it running now need to set up the shift as it makes noise going in gear
skinny1965
thanks a ton got it running now need to set up the shift as it makes noise going in gear
Fishermark
Are you shifting firmly into gear? Or easing into gear? A good firm shift is necessary, anything else will grind regardless of the adjustment.
