alpha shift cable install two grommets? ?
kramerpage
Read the #6 manual and cannot find the instructions for these two items. OEM merc lower shift cable kit. # OC735235 gimble. Thanks guys
Watermann
The nylon insert that goes in the the transom assembly to protect the shift cable sheath. Part # 14705 for my Alpha One. Not sure about the long one in the pic.
fetch
Watermann
The nylon insert goes in the hole where the shift cable enters the outer transom assembly and passes through into the inside of the boat. The transom assemblies are the 2 halves that bolt together with the transom in between them, there's the inner and outer assembly.
kramerpage
Got it guys thanks. I will chuck the long one in the trash. Letting bellows glue dry overnight so I can tighten clamps a little more.
Watermann
Some of the A1 Gen II diagrams shows the long one in the outside assembly.
