Aluminum Boat Rebuild Methods by 191Seanymphstriper
191Seanymphstriper
191Seanymphstriper
Re: Aluminum Boat Rebuild Methods by 191Seanymphstriper
I ripped out the wood floor and foam I sanded the iner hull and sprayed her down with some primate then primer and some new grey paint. It wasnt a 4 day job it was a 12 day process. Im just making it sound easy. I cut some new plywood out and resined both sides and then got some spray glue and new carpet. I then installed everything and she came out great! I then got a new battery plastic and installed a power shut off key and installed running lights and a vhf and vhf antenna. As well i installed a cigerette lighter for the old spot light. Added some switches for the running light vhf and cigerette lighter and bilge pump that i installed.
I got a new cover for her and a newer sprint trailer! i used her for about 2 months even took her offshore to collar banks 8 miles from jones inlet on a nice day! I love doing inshore and inlet fluking but i also like doing strippers and wreck fishinhg for black fish and porgy. I loved the boat. Alot of fun. But being that i have 2 kids now 9yrs and 8yrs and they love to fish the boat was a little small and unsafe for them in the inlet. I also wanted somthing bigger so I could go out in the ocean on nicer days. At the time i also couldnt afford 2 boats so i put this one up for sale and 2 weeks later she was gone..........
Originally I was looking for a bigger 161 fm sea nymph side console or a starcraft and came upon a 171 cc striper center console sea nymph striper... Wow was I impressed! This was a 1982 light wieght easy to trailer 17 foot cc with a 50hp 3 cyclyner 82 merc that looked well taken care of. I called the guy went down there and brought it home. Wow I was in love with it! The floor was in bad shape but the hull was in excellent shape. Console controls ran great etc. So I gave her a check over changed the lower unit oil spark plugs and fuel filter and hit the water. Wow she did 29 mph with the kids and gear. I had 2 6 gal fuel cells and she ate nothing. She had very high gunnels and a fort knox style back splash! It was perfect for the kids and was great because I was able to hit the ocean on nicer days! I intalled a new bilge pump and other then that she was all set up for stripers! Caught lots of fish with this boat. This was a good luck boat! i miss this one:( When winter came around I took it out of the water and took the motor off and the center console. The transome was in emaculate condition. So I did not replace it! No rot etc I couldnt believe it. The floor on the other hand was in poor shape. So after ripping the floor up surprizingly the foam was in great shape. I marked each piece and removed it in large chunks kinda came up in one large piece minus 3 or 4 pieces that came up in 2's...
I got out the wire wheel and went to work with my heat gun and machine. In 1 full day she was as clean as a whistle. I then got my fathers very large compressor 55gal and a sprayer that i borrowed from a friend and ordered white ryno lining from a local shop in town and went to work. The reason why I choose to spray the entire inner hull with ryno lining is because I seen the process done and the stuff is bullet proof and comes with a lifetime warrenty! I spoke to the rep and he said that not only will rtno lining quite the ride of a aluminum boat, it will seal it because its very very thick and its self leveling as well. It will also make clean up a spray hose type job and will always look clean! Also if you knock a sinker into it it will not scatch or nick like paint will and can! After picking my fathers brain and taking about it I decided to go that route. It came out flawless........
Now after redoing a floor in the 141 FM sea nymph I said to myself. There has to be a better way. I was planing on keeping the 141 and then keeping the 171 cc and said to myself. I only want to do this one time and want it to last forever! .....
So I thoiught of star board. Star board is that cutting board type plastic material that comes in (NONE SKID)plywood size sheets made for boat decking. quarter inch thick half inch thick 1 inch thick etc.. It also comes in different colors white black blue green off white etc.......
This material has been used on boats for over 20 years now. Electronic boxes fish boxes decking etc.... So I looked some up on line ordered it and wala it was perfect. I cut it with the same tools I would use for wood and the job came out better then expected. Now My 141 sea nymph I did with wood, resin,glue, Carpet. The sea nymph had no leaks at all. The wood then resin then glue then carpet is very heavy and star board half inch isnt light either but comes in about the same in wieght then the wood and resin glue and carpet.....
Another reason i went with the star board is that the decking is now more like a fiberglass boat that I am used to. A nice deck you can wash and hose off. No more replacing wood. No more glue and vinyl coming up. No more smelly carpet etc. No more soft spots and soggy wood to change every 7 to 15 years etc... This stuff should have been oem equipment! http://www.interstateplastics.com/search.php?searchtext=starboard&gclid=COq8x8vN3aMCFZxo5QodN2GLlg
191Seanymphstriper
Below is a picture of my pop coming down to see and check my progress on the 141. He had gained some weight and was to sick to take a spin on her but he really loved the way she turned out and was proud of me! I think another reason why I like rebuilding these is because it gives my pop somthing to do on the days that he is feeling ok! He had helped out with the 16 star craft that I dont have any pictures of for some reason and we enjoyed spending time togeather fixing that tiny up!
(Just to let you viewers know pop is still around and doing ok! Thank the Lord! :) )
(IM NOT COMING DOWN ON STARCRAFT AT ALL I LIKE THERE BOATS AND OWNED ONE! I just had no luck finding a good one that wasnt beaten up or abused! )
If you can make money from doing what you love then why (knot)........ My father always told me...........
191Seanymphstriper
Heres my old 1982 171 cc sea nymph striper i gotta tell you this seanymph is just like the 191 but smaller but alot lighter. Its a great center console boat set up just right! I miss this 1 alot!
And here is the pictures of my 1987 191 sea nymph striper cc center console!
Woodonglass
Whoa SNS,
Picture Standard is 640 X 480 Please Re-size your Pics.
I'm just sayin...:D
191Seanymphstriper
I dont know how to do that maybe the master of the forum can fix it for me. I picked up a 21 starcraft cc today to rebuild. I will get some pics up soon! I got her cheap 500 cash and is surprisingly very clean! ( UPDATE! Ok I figured out the resize thing.)
You see how deep she is for my kids 34 inches of free board in the rear and 36 in the front! As oposed to the 21 staircraft that is 28 and a half in the rear and 28 inches deep infront of the console
heres a picture of me from last year out in the atlantic ocean by the J.I Buoy You can see a little land behind me. Im sitting on a newly installed iglo cooler with a new cusion that at the time I had just installed with tie down straps etc...
191Seanymphstriper
Since my sea nymph is already in the water and sea worthy at the marina and I use her daily. I think on rainy days I will start to rebuild the 21 starcraft and well. geter done................ Then when she is finished I will start the 191 sea nynph rebuild.
Bob_VT
Absolutely NOT. The Moderator team are not your repairman. :mad:
Please pay attention on how to post to a forum. A few paragraph breaks would make your post readable and not painful.
Photo size is 640 x 480.........
191Seanymphstriper
WOW! That was a little harsh! Well I fiqured it all out! Thanks anyways! "THEY ALWAYS TRY TO KNOCK ME DOWN BUT I JUST KEEP GETTING BACK UP AGAIN!"
MTboatguy
Learning to use the return key, would make it a heck of a lot easier to read your information....
Not harsh, just reality..
Often times not using typing rules, makes it more trouble that it is worth to read the information.
Now I learned this the hard way when I was in the military, I actually lost a pay grade because my reports were not typed correctly and I had a very anal commanding officer...so after that, I learned real quick!
:eek:
191Seanymphstriper
Thanks MT! (O boy! LOL! :) Ok I got the 21 cc starcraft home today. The trailer is way to small for this vessel so I will be needing a nice trailer! Also I wanted to post if you use craigslist to search for things and use internet explorer I found this website that searches multiple citys without having to change your browser to fire fox or somthing different etc... Heres the link
http://www.searchtempest.com/
OK! I have to say! I am empressed with how much space she has in the rear. Makes the sea nymph seem alot smaller being that she is only 2 feet larger and I figured out why! The sea nymph has such a large center console that you would see on most 24 to 27 foot offshore center consoles and the starcraft has more of a lower profile shorter center console and that 2 feet in the rear is very nice I must say! I will be taking some pictures tm after work and then I will be removing the console tm and if that goes well I will be beginning on removal of the floor!
191Seanymphstriper
Ok! After taking some measurements etc I am not happy with this 21 starcraft cc! Its not a very deep hull and the deadrise looks like in a chop youll get wet some. Its deff not built for rough water like the 191 sea nymph striper I will be taking some pics of her and putting her in the garage to rebuild for profit and I will record progress with posts and pics. I have a set of 2009 70hp etec 4 strokes with 73 hours on one and 70 hours on the other. I think ill hold off on putting twins on the 21 as I had planned on. Her hull is not desrving enough for twins. She is more of a really nice sized bay boat! I will look for a used older 115 or 150 merc 2 stroke that was used in freshwater with good compretion etc and put that on her!
I will save the twin 70 etecs for the 191 sea nymph after her overhaul rebuild this winter! She is a very dry boat with a very deep V and very deep gunnels and I have taken her offshore some already. But after her rebuild and with the twins She will really be a nice performer! And a stable fishing platform
I have decided to buy a 26 starcraft ISLANDER with a I/O and rip out the old dirty gas gussling turtle I/O and turn her into a 26 Ft offshore center console with bracketed twin 100hp or 150 hp outboards to show all the guys at starcraft, who think they know what there doing when it comes to a cc offshore boat how its done correctly and perfectly!
This rebuild will be for my personal use not for resale! I have found a few and will be making offers tm afternoon and see if I can get one here asap. The weekend is coming so I will prob just clean up the 21 cc starcraft's flooring etc. I havent been home in the daylight hours so no pics yet. Ill get them up a.s.a.p ........
I took the 191 Seanymph striper out of the water today I keep her docked in the water in Freeport Long Island. But because of this huricane we may get I pulled her out of the water. She has some growth on her even after applying the petite aluminum bottom paint so I will break out the presure washer tm and get to work on removing some growth and barnicles!
Today I installed a kicker steering bracket bar that I purchased from west marine. It was a easy install and is a quick disconect bar so im very pleased. Now i can troll the beach with the 8hp and steer her from the helm. I had to rig and install a steering bracket on the old evinrude kicker because she diddnt have a steering port handle like most 9.9 or larger outboards. But all in all I am very pleased with the install!
Bob_VT
Great pictures.....nice boats. We really do have a large amount of aluminum boat addicts here ;)
Bob_VT
I have decided to buy a 26 starcraft holiday with a I/O and rip out the old dirty gas gussling turtle I/O and turn her into a 26 Ft offshore center console with bracketed twin 100hp or 150 hp outboards to show all the guys who think they know what there doing when it comes to cc offshore boats how its done correctly and perfectly!
Good luck....... I think the Starcraft people here have done things correctly and perfectly....... we are always learning new tricks but many of us are old dogs and tend to be hard to teach.
We are often out-numbered but not out-smarted;)
Huron Angler
Nice photos, and nice rigs there:)
My dad bought a 1986 Sea Nymph Fish-N-Ski 19' that is identical to your 19' CC right down to the paint:D
We used it in the Great Lakes trolling for salmon from '86 thru 2001 when he sold it to buy a 24' Seaswirl.
He now wants to sell the fiberglass rig so he can buy the same boat back...but the guy wants to keep it. It's been garaged a mile down the road and hasn't even been used. We will get it bak someday. It even still has the original 90hp Johnson on it and our old 10hp kicker.
He is now looking for a CC Sea Nymph Striper or Starcraft mariner.
So I know how you feel about the Sea Nymph hulls. Great boats, built just like all the Starcrafts. Actually was started by the same folks after they sold Starcraft back in the day.
Good luck with the projects, you seem to have gotten some great prices on the resale.:)
fshngho
It certainly looks like you know what you are doing and I look forward to getting some tips and advice from your resto thread. I don't believe anyone else that has or will restore a Starcraft on here does it as a profession. We do it for the enjoyment of the boats and sharing with other nuts on here. Heck, even with our mistakes we still get encouragement and advice. Most of us don't have the resources to build a perfect boat, but we do what we can and are proud of the outcome. Its nice to see the custom ideas of approx 300 people and I certainly am blessed they allow me to be here. I believe getting there is half the fun and with these guys getting there with them along for the ride is MOST of the fun. Take a look at some of the finished projects and you will see the brotherhood I refer to. Take care & good luck.
Dale
191Seanymphstriper
I tell you Bob I think because there so easy to tow and theres not tons of them here on the south shore with all the salt water we have. I just love them! There quit uniqe! ;) Thanks for the complements!
191Seanymphstriper
LOL! Bob I was just busting balloons! I think most rebuilds and restores I have seen have been just great! Especially N.B LL I think he really got that classic rustic vintage look and he did it with class.
I have had this idea to do a 26 islander for quit some time now! Kinda like N.B's 22, And im in a better posision in my life now as apposed to 2 years ago to do it now. And now I can do it the right way! Meaning the way that I want to do it without taking short cuts! Not meaning that someone isnt doing things right! I guess the way i worded things it came off sounding the wrong way!
I have been thinking of ordering a new custom welded 33 ft aluminum hull and building a cc. But before I do that it is way cheaper to try the 26 islander hull and do things my way and see how she turns out before I go spending lots of money that I don't really have! And if the 26 performs the way I think she will after im done doing the math and caculations and pre prep design of the fuel cell placment, battery placement, console placment, fish box, bracketed twins etc... Hopefully she will handle well enough where i will be satisified..
I will never sell mt 191 Seanymph striper. She will always be my bay/inlet and semi offshore boat. She handles great and is very cheap to run.
But I do need a bigger boat to do the 100 to 130 mile runs offshore!
If this 26 hull works out. I will be keeping her out of the water and she will be a strikly used offshore vessel for tuna and shark runs
I think when im done with the 191 I may be able to get 70 miles offshore to do some tuna. But I think I will keep her as a 40 mile or less ocean boat after I add her fuel cells and water etc!
Im thinking on a nice day the 26 islander hull will do just great for a 100 mile or more run! I cant wait to get started on that project!:) I just need to find a slaming deal! Im in the works of trying to close a deal. but she is far and will be purchased without previous viewing. Not the way i like to do things but if i get her cheap it will be a closed deal!
