hwsiii
- Joined
- Jan 25, 2009
- 2,639
Re: Am I spinning my prop enough rpms?
tmt, what happened when you moved the motor up was not what I am used to seeing. Usually the RPM goes up and speed as well, and going by the numbers I show that your speed went up 1 mile an hour but your RPM went down 100 RPM, and that is not the way it usually works.
I am assuming that the setback and the angle of the 2nd step is reacting different than I am use to or could it be that the numbers you gave me weren't exact from the initial testing but were just close. I need to think about this until tomorrow and I will get back with you then.
