Subliminal
- Joined
- Oct 21, 2009
- 555
Re: ...and she's finally in the driveway!
Yeah, they were doing some construction on the highway, so what should have taken slightly under an hour took almost two.
But, we had a good time, anyhow. And the boat ran relatively good, although I did encounter a few issues.
The first time out, the thing started right up and ran like a top the entire day. I do notice a little hesitation when I first hit the throttle, but I'm guessing (hoping) it is the transmission engaging. I have the Volvo drive, and I've heard that it engages some kind of cone system, instead of just gears that clunk together.
When I first hit the throttle it will fire up a bit then hesitate about a second then it'll fly right through the RPMs. Anyone know if that's a normal thing?
Also, I looked for the speedo hole to see if there might be any debris and promptly realized I have NO IDEA where that'd be.
Oh, and one of the screws in the latch that holds down my swim deck (and the motor housing) was apparently stripped from the factory. I initially tried to fix it by drilling out the swim deck a bit and using one of those plastic sheetrock anchors. That held for about, oh 2 hrs, until I was driving down the road, looked in the mirror and saw that it not only ripped that screw back out, but the other as well and the platform was flapping in the wind on the trailer.
So, Saturday night I took the entire platform off, drilled the holes out a little bit, cut a piece of dowel to fit, put some waterproof wood glue in the hole and jammed the wooden dowel in there...then I waited a day for it to dry, drilled the hole out a little small and reattached the latch. Good as new... which is good, considering the boat IS new. DURP!
