Re: Anode Life in Fresh Water?
Thanks a lot you guys for weighing in. The anode is corroded, but not eaten away like I made it sound.
The slip is powered, with 120V GFCI connections all around. I have a single outdoor extention cord going into the boat plugged into a non-ground battery tender.
That could be you're problem right there. A couple things to know about electricity.
Transformers are floating. Because the battery charger you are using does not have a ground, you may have a voltage differential between the - output of the charger and absolute ground. This will create electrolysis between the floating - output and the path to ground. In you're case it's your metallic drive/anodes and salt-water .
GFCI plus are never 100%. I recently bought a house, and the house inspector used a device to test the GFCI plugs in the bathroom and outside. 3 out of 6 plugs failed the test, even though when you test them using their own built in test button they trip. In theory, if you DID have current leaking to ground through your drive, it SHOULD trip the GFCI circuit, but not all GFCI plugs have the same sensitivity. Many of them can still allow a small amount of current to "leak" out of the circuit and not trip them.
Most battery chargers will tie their "floating" transformers to something. More specifically, they will tie their - output to ground. Seeing as how you're charger has no ground connection, it cannot be tied to ground, and thus could be causing the corrosion.
A simple way to test:
connect you're charger, and use a multi-meter to measure the voltage differential between your - battery terminal, and the ground on the extension cord (the ground that your charger is not using)
Try looking for Mili volts in both AC and DC modes (because of the bridge rectifier in the charger, I'm not sure if the overall voltage differential will be AC or DC)
If you see any measurable voltage between your - terminal (also you're drive) and ground, than you should either
A) Buy yourself a new charger (with a ground)
or
B) Tie your charger to ground, by running a wire from the ground on the extension cord to your - battery terminal.
