anodes replacement
m&m252
i find myself replacing anodes again 2nd time in less than 1year. i have twin merc opti 150 salwater 2005. equal wear on both anodes on lower units . on one occasion only had screws and no anode plates @ lower unit . are these anodes getting cheaper/poorer in quality??? I keep my boat on a canal on davits /not touching water . where is this wear to the anodes coming from???
achris
More fish than mountain goat
Re: anodes replacement
If your boat is aluminium and the anodes are eroded, then the engine anodes are trying to protect the hull as well as the engine. if your hull is 'glass, then start looking for stray currents. Is there someone near you who is using 'shore power'? Or are you? If shore power isn't isolated properly then you can watch the anodes disappear.
Chris.............
m&m252
that was my first concern , does someone in my canal have an electrical cord in the water ??? i have my neighbor across from me that has his boat on a submersible lift he shut off the power when not here,but i do have others in canal in the water shore power connected ??? will need to start checking nearbys....
