Another "Joe Reeves" method question...
Berdink
If I know without a doubt the TDC mark on my 1994 Johnson 90hp v4 Crossflow flywheel is accurate because I checked it to make sure.
Can I use the "Joe Reeves" method to verify timing on this motor?
I disconnected the cables.
I opened it up to where the carburetors are fully open, the roller in the slotted area in picture below is fully bottomed out at the top of the slot - the picture is not mine - mine is completely bottomed out at the top of the slot where I have circled in red.
If I'm completely bottomed out there at the top of the slot, it's there where I crank the motor and check my timing mark and if the manual says 28° BTDC, I set the timing at 24 degrees before TDC , correct?
I know this may sound like a stupid question. I'm becoming less confident in my old age. 😊
1000020042-jpg.418688
Berdink
I really can't see how I can get any more WOT if I'm up tight against the top of the slot.
I am going to be blunt here.---Only if throttle plates are not horizontal at full throttle,----Take a good look at linkages to see where adjustments can be made.----But do not adjust anything if you are unsure.
Berdink
Throttle Plates are horizontal - they are fully open when I bottom out at the very top of the slot.
Berdink
Please be blunt...
The only reason I'm looking at the timing is as l mentioned in another thread, I feel like this motor isn't reaching it's full power.
Using the Joe Reeves method, I was setting at 18 degrees before TDC, when I should be at 24. Motor specs is 28, so I should be at 24 with "Joe Reeves" method.
Berdink
I'll have time Monday to verify if the flywheel is still correctly lined up with the woodruff key.
