Berdink
Thread starter- Joined
- Mar 5, 2020
- 560
If I know without a doubt the TDC mark on my 1994 Johnson 90hp v4 Crossflow flywheel is accurate because I checked it to make sure.
Can I use the "Joe Reeves" method to verify timing on this motor?
I disconnected the cables.
I opened it up to where the carburetors are fully open, the roller in the slotted area in picture below is fully bottomed out at the top of the slot - the picture is not mine - mine is completely bottomed out at the top of the slot where I have circled in red.
If I'm completely bottomed out there at the top of the slot, it's there where I crank the motor and check my timing mark and if the manual says 28° BTDC, I set the timing at 24 degrees before TDC , correct?
I know this may sound like a stupid question. I'm becoming less confident in my old age.
