reptileguy
- Joined
- Jun 16, 2011
- 48
Hey guys I will give you a little history about the problem and what IV done to try to fix my aq125a. Engine will not get above 2100 rpm under load ,it stalls out and I can't even feather it higher I hear the carb open up sucking air loud. I can rev it up to 3500 no problem in water in neutral and it idles at 1100 then 900 rpm in gear. I have compression tested and is 147-150 psi across the board I have replaced all fuel lines and filters , cleaned pick up tube, screen filter and anti syphon from fuel tank I have lots of gas going to carb .rebuilt carb 2 weeks ago set mix screw 2 1/4 turns out. I have checked timing belt and did not skip a tooth . Set points to 0.016" . Timing light says 10 degrees BTDC at 1100 rpm advance goes to 30 degrees BTDC at 3000 rpm but jumps all over the place any higher rpm than that. Don't think that's normal but not sure . I have followed hundreds of posts regarding this engine on here but never seems to fix my problem any help would be great
