stoneSWH
Thread starter- Joined
- Mar 17, 2013
- 19
I have read many answers to "Water in Cylinders" questions, and most of the situations were semi-catastrophic. I don't think my situation is that bad, but I would appreciate some tips based on the following information and assumptions:
1) Inboard 2006 Vortec 5.7 L with closed-loop cooling system - only elbows see raw water.
2) Removed all plugs for compression check (that's how I found the water in the port cylinders).
3) Stern-down attitude of engine let water into #7, #5, and #3 (no water in #1).
4) Removed elbow. Appears raw water entered exhaust manifold through failed elbow gasket.
5) Removed exhaust manifold. Turned over engine. A little water sprayed out of exhaust ports, but did not gush out.
6) I turned the engine over until no water spray or vapor came out of exhaust ports.
7) Engine turned easily, so assume not enough water in cylinders to cause bent push rods.
8) No water made it past the pistons into the crankcase.
Here are a couple of questions:
1) Is there anything I could/should do before I replace the exhaust manifold and elbow? Like squirt some oil or "Seafoam" or something else into the cylinders through the exhaust ports and turn the engine over to lubricate and clean the cylinder walls?
2) Once I saw the water on the plugs, I did not continue with the compression check. Even if I don't get great compression readings, does it make sense to go ahead and install the plugs and try to run the engine on the chance that any possible valve issues due to a couple of weeks of exposure to brackish water will resolve under the heat, pressure, and mechanical action of a running engine?
Thanks!
Thanks!
