Another Yamaha Idleing Problem
Scout Sport Fish
Ok so I start up my 2000 130 HP 2 stroke and it runs "ok" after a couple secs it slowly spins down to about 5-600 RPM and then spins down to literally like 5 RPM and cuts out. Now its ok if I give it a little gas while not in drive to keep it at 10000 RPM and it runs great at WOT. Could the idle screw just vibrated loose or is a deeper problem such as fuel flow or carbs?
Thanks in advance.
Ray Neudecker
Re: Another Yamaha Idleing Problem
Check the idle timing screw to be sure it hasn't vibrated loose as well as the idle air screws.
dpfundst
Hi,
Where is the idle adjustment screw located on a 90HP 2 stroke 90LTRZ
Thanks
Dwight
Scout Sport Fish
Well turns out it just needed a new fuel/water seperator. The one that was originally on was WAY to small for the engine and gas tank so I got a whole new rig on.
