Any way to tell if lower unit is good....
btroy
Any way to tell if lower unit is good if it is uninstalled? I have a Mercury 150 spare motor and have removed the lower unit. I was told it was good but dont want to take mine apart and replace it if it is no good.
BTW mine has no reverse.
Older Mercurys 77 models. Power of tower type motors.
Thanks
Troy
Faztbullet
Re: Any way to tell if lower unit is good....
The only real way to tell is to pull carrier and inspect gears and clutch dog and install a new impeller while its off....
Chris1956
Honorary Supreme Mariner
Troy, it is only a few minutes to switch gearcases. If your reverse is bad, it sounds like swapping is in order.
The spare gearcase if from an inline motor as well?
btroy
I will try the swap after the temp warms up, 20s here today.....
thanks guys
CharlieB
Is your Reverse really bad?
Have you disconnected the shift cable and manually shifted it to see if maybe the cable has stretched and needs replacement?
Hate to see you swap LU's and still not have Reverse, then pull either unit apart and find nothing wrong!
Always remember the K.I.S.S. principle, check the easiest things first.
