nlain
- Joined
- Nov 17, 2005
- 2,445
Re: Anyone tried a Turning Point Hustler prop. (RESULTS)
I purchased a TP 14X23 for my boat, SeaRay 185 Sprot, 4.3L Carb 190 HP, 1.81 Alpha, dry weight per SR is 2650, plus 26 gal gas and stuff. It came stock with 14X23 so I tried the same in TP, gained speed in the cruise range, 3 to 4 mph, killed wot rpm and mph, called TP told them what had happened they swapped for a 21 P I paid $10.00 fee, covered their freight, I returned old one, they sent in new one. The swap was depending on the 23 P still being in new condition which it was. So if it still does not work out they may swap with you. I did not gain any wot speed by changing to the TP but with the swap I am at least back where I was. I do have Smart Tabs, Stainless Steel version, and did not make any setting changes, I had played with them on the stock prop to get the best performance, so I felt no need to change the settings. You may try calling them and see what will happen.
