anyone want a kid?
dafox99
Well, I went out of town for a couple of weeks. I just went out for a little spin in the boat. Boat was on the lift crooked .. anchor tied to the thottle and then to the dock. Oh well, I lower the boat, push off, and nothing. I noted that the key had been left on. With no paddle, I'm watching the dock slowly disappear. I paddled in with a life jacket. My kids know they can take it out anytime they want, but man, are they grounded forever.<br /><br />So, the battery is completely dead, and I'm charging it now. It's a 1965 40 hp electric shift. I also noted the throttle was in reverse. I would imagine I drained the battery through the reverse coil and the points to an ignition coil. Anyone have any ideas on if this thing will start (melted/burned points) and still have a reverse gear?<br /><br />Thanks
rodbolt
Re: anyone want a kid?
the points are not 12v on that model, the reverse coils were if the selector was in reverse with the key on. and the voltage regulator may have taken a hit, all you can do is fire it up and see. that motor can be rope started as well. ign system is not battery dependant but the shifting is.
dafox99
AH .. I forgot about the dang rope! The battery was dead when I first got it, and the generator was not working (I later "polarized" it and it has worked great ever since). I replaced a coil, and pulled the rope .. started first pull! So, I thought we had the battery going to the coil, through the coil primary, through the points to ground .. so if the key is left on, and the points happen to be closed (likely), we burned up the points. No? That's at least one piece of good news. The regulator seems to be three relays .. guess we could have burned up one of those? I'm told the gearcase coils are tough to find. I'll fire it up in the AM. Hope it works.<br /><br />Thanks.
rodbolt
no worries on the points. they are not connected to anything 12volts. the reverse coil may or may not have survived. we will know in the AM :) <br />its all about the anticipation :)
dafox99
Agreed. Which is why I probably won't sleep tonight and will likely go down to the dock around 3 AM. Will let you know. thanks again!
rodbolt
hahahha<br /> I hope I am not awake and posting by then but it wont be the first time.
dafox99
It's builetproof! Runs like a striped ape. Whatta motor! Thanks.
