Aq125A Replacement Engines
warlock73
I have a 1982 Bayliner Capri w/Aq125a and a 270 outdrive. I bought used and am restoreing it. I was wondering if anyone might know how I might go about finding what other engines I can put in it that fit. I would like more HP.
at 4000rpm's I get rattleing in the motor. Instead of a rebuild I would like something bigger. Is there an upgrade website or something that can tell me what will fit or is that wishful thinking. I was told a small block chevy 350 will fit. Any ideas guys. I'm getting ready to store for winter and would like to know so I can start saveing cash now for the spring.
TowRoper
Re: Aq125A Replacement Engines
dont know what swaps fit but i do know the od gear ratio will have to be changed too
PiratePast40
With enough money, you could do anything you wanted :). Realistically, the other AQ series 4 cylinder engines are an easy swap. To go to a V6 or V8, you'll need to change to a "Y pipe" for the exhaust plus you'll need to change the transom shield to one with the appropriate bypass holes. As TowRoper said, you'll need a different lower gear ratio as well. Plus you'll need to add some front motor mounts. There are quite a few threads on the topic and you'll see that most end with the conclusion that it's probably not cost effective - not that it can't be done if you have the parts and money available:D
warlock73
Well then.....I might as well fix the rattle. I am assumeing its the valves thats makeing the noise, but I'll have a guy check it out in the spring to be sure. Thanks guys.
PiratePast40
You might want to start doing the investigation and research during the off season. Come spring, it might be harder to find help.
