74bayliner
- Joined
- Aug 23, 2011
- 607
Re: AQ130D Cam bearinss ?
I had the crack between the valve seats show up when I got my head tanked and inspected. the machine shop guy was nice and said he would only charge me 20 for the tanking... so i went to canada (closest i could find at the time) and picked up a b20 automotive cylinder head.. it was than tanked and inspected and found to be perfect... but there are a few modifications such as the Thermostat Housing is different on automotive so you need have machine shop drill a hole for the bypass tube as per one of my earlier posts... once that was done i was happy. the only other issue i saw was the temp. sender hole was bigger than the thread size of the temp. sender so now i have to modify that...
but i hope that yours is fine which im sure it is if you had the machine shop plane it.
