aq131a dead all of a sudden
Ed Idaho
A while back I posted a Solex carb problem and the forum helped me out... it just started running perfectly. Better than it has in years! But now I have an electrical problem. Turning the key and it is dead dead dead it was running great... parked ..turned it off Went to start again and its dead. I checked all wires ..numerous times cleaned contacts once in a great while it will turn over but 99% most of the time nothing could it be that four pronged relay near the 40 amp fuse? it is a volva aq131a is there a way to test the relay and or fuse
NOTHING WORKS ON AN OLD BOAT EXCEPT THE OWNER :)
no704
Check that when you turn the key you get voltage to the starter, coil, etc. try fiddling with the throttle when you try to start might be a bad neutral safety switch. Good luck
Ed Idaho
Thanks
I will head back out to the houseboat and try this starting trouble shoot
Ed Idaho
OK HELP I took all the trouble shooting directions and testers and when I arrived at the houseboat it started right up (i scared it?) all i did was twist the key
it is a 1985 three buoys house boat it has no neutral switch i can start it in gear HOW did it heal itself batterys are great and solar charged good volts i tried for hours last monday no luck dead dead now 2 days later it starts every time no matter if i wait 2 minutes or half hr or hr it starts cold or hot any ideas where the problem might be?
jerryjerry05
Sounds like the neutral safety switch?
Or the main harness connectors need to be WD'd
