soggy_feet
Thread starter- Joined
- Oct 10, 2009
- 713
I had a local speed shop tell me you can't use a truck engine in a boat because the clearance between the pistons and cylinder are greater on a marine engine, reasoning that marine engines run cooler thermostats and under load the block won't get as hot and therefore won't expand to the same degree as the piston, possibly causing the engine to seize.
He said the difference was .001" between bores.
I'm having a hard time believing that .001" is going to make a difference. Ever.
You still have oil transferring heat between parts, and you still have the clearance designed into the piston/bore fit.
Anyone have an opinion they'd like to add?
