JustJason
- Joined
- Aug 27, 2007
- 5,377
bruceb58 said:~~
The heat range is controlled by the ceramic insulator size. It will control pre ignition. Maybe that is what you are thinking. Pre ignition will cause things to heat up if the explosion is too soon. If that's what you meant then I agree with you.
No, that's not what I meant. What I meant is that it does help regulate the temperatures of the cylinder/combustion chamber/whatever you want to call it. Heat range does help control the heat of the plug itself, but also the combustion chamber. The hotter the combustion chamber the hotter the plugs going to be, tip and body. The cooler the combustion chamber the cooler the plug is going to be, tip and body.
Try and envision this. Take 2 identical engines, and have them run side by side on matching dynos, with the load on each engine being the same. And you run them for a period of them. Shut them off. Very quickly pull a spark plug, and then drop a thermocouple down the plug hole. The cylinder with a hotter plug will have a higher temperature than the one a cooler plug. I'm not talking about the temps of the plugs, I'm talking about the temps of the cylinders.
That's what I'm talking about. That's what NGK is talking about on that web page link I gave you. And that Is what is being taught in the tech schools as well. The plug helps radiate cylinder heat into the cooling system, or it helps to prevent that, and keeps the heat in the cylinder.
